13 years, 1 month ago.
UDP packets print as garbage
Im testing a Wifly module and using a VB6 form with a winsock control. Im receiving an expected broadcast packet in my VB form but the text is garbage. The packet contains basic identification from the wifly. Any suggestions
Hi Gregory, you will probably get better answers if you publish the code showing the problem. See http://mbed.org/handbook/Asking-Questions
posted by Dan Ros 01 Mar 2013
I found in the end that I first had to convert the bytes to hex then convert the hex to ascii
posted by Gregory Martin 02 Mar 2013
Taking a look at the reference manual of the wifly module, it appears that the UDP broadcast message is a predefined massage containing several info such as: mac address, channel, rtc time,...
For more information on the UDP broadcast messages, take a look at the http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Wireless/WiFi/WiFly-RN-UM.pdf manual p51.
Cheers, Sam
