11 years, 5 months ago.
PWM on PC_7
Hallo, I'm tring to set a PWM on PC_7 but this example doesn't work. The debugger (I'm using keil) is blocked after the execution of the constructor function. Any suggestions?
Thank you.
Regards.
A.
Try commenting out the printf function.
Hi Eric, by looking in the pwmout_api. c I can see that the Timer 4 (that should be used for the PWM on PC_7) is just used for the us_ticker. This examplains why when I debug the code I find the debugger blocked inside the us_ticker functions. /media/uploads/andreatoscan/pwmout_api.c
Regards
posted by 14 Oct 2014
