11 years, 5 months ago.
compatibility
Hi i've a nucleo f401re mbed board and trying to use "ModbusTCP_modified" library with my wiz820io device. and i'm using WIzNetInterface library in my project for wiz820io module. thus i should bring together modbustcp library and wiznetinterface lib. originaly Modbustcp_modified example uses "EthernetNetIf" ethernet library. there are many mismatched point between Modbustcp_modified and wizınterface library. What should i do. what's suggestion about this situation. Thank you.
Hi, I don't use ModbusTCP library and I can't help you.
even so thank you Slawek.
posted by Alican KAYIKCI 14 Oct 2014
