11 years, 5 months ago.
what exactly are signals??
what is the use of the signal_wait, or signal_set??? i cant find a use for it and i dont understand where does the signal come in hand in the example
7 years ago.
For any future readers, since I find that mbed is not very beginner friendly...
If you find the mbed ways too difficult, you can use this guide for Keil CMSIS RTOS as well. https://www.keil.com/pack/doc/CMSIS/RTOS/html/CMSIS_RTOS_Tutorial.pdf
I've done a little program which uses signalling in the way specified in that tutorial: https://os.mbed.com/users/Ritzerk/code/RTOS-Example-RTOS-Interrupt-as-Thread-us/
Hope it helps.
11 years, 4 months ago.
It's a thread-safe way of signalling between threads. You can have one or more threads call signal_wait(), and they will block until another calls signal_set(). You can have up to `osFeature_Signals` (probably 8; max 31) signals in each thread, and threads can wait for a comination of signals by using the `int32_t signals` bitmask.
See http://www.keil.com/pack/doc/cmsis/RTOS/html/group___c_m_s_i_s___r_t_o_s___signal_mgmt.html
