11 years, 5 months ago.
ethernet
I need to use rj45 Ethernet socket (Pulse Jack, J00-0045NL) for my project but I am not using mbed application board I need to connect Pulse Jack, J00-0045NL to LPC1768 can u help me with the physical connection please.
you need to connect ethernet pins of lpc1768( Rd+ Rd- Td+ and Td- )to the pulse jack. the physical connection can be found on the following link : http://developer.mbed.org/cookbook/RFID-Tweeter
as far as software is concerned you need to import standard ethernet libraries (there are many ethernet libraries for lpc1768). and write a basic test program
EthernetInterface eth;
eth,init();
eth.connect();
printf("connected, ip address is %s",eth.getIPAddress());
is that all nothing to do with the PHY chip, and some passives and a 50MHz clock
posted by faizan ali khan 09 Oct 2014
If you're using the actual LPC1768 mbed board, that should include the PHY chip on the back, so you just need to wire it up to the RJ45.
Jez
posted by Jez Cawley 09 Oct 2014
