11 years, 6 months ago.
library compatibale wiz820io
Hi , may i use this library with my wiz820io module? i'll try but i wanna know if there is a trick which i can't find for wiz820io and nucleo f401re device. Thank you.
Hi, If you use wiz820io, then I suggest another library..
Import libraryWIZ820ioInterface
Custom and bugfix
W5500Interface library also refer this library. It may very useful for you. and, should modify code of information of spi pins (name or port name) in main.cpp. becasue each of mbed board may have different pin names of SPI.
