13 years ago.
sending commands via usb to mbed to control PWM or analog out
anyone have a simple program that accepts simple string commands via usb that i can parse to control PWM or DAC output?
rgds,
13 years ago.
Try looking at the RPC over serial features - they may be a good starting point!
HTH
Jez
Dave Tung
poster
13 years ago.
Jez,
thanks for the suggestion. I'll take a look and see how the RPC goes. Is there anything in the mBed classes that might also work?
dmt
13 years ago.
You can also just use a serial object via the USB port, and then write some code to decode the message and set the PWM/DAC accordingly.
13 years ago.
The simpelest is ..
PwmOut myled(LED1);
PwmOut myled2(LED2);
serial pc (USBTX,USBRX);
    while(1)
      if(pc.readble()))
        float brightness, brightness2;
        scanf("%f,%f", &brightness,&brightness2);
        myled = brightness;
        myled2 = brightness2;
then from pc, send two commer seperated values (or however mainy)
followed by CR.
This can be done from Lab View, Delphi, or just boring typing.
Enjoy
Ceri
Ceri, Erik and Jez,
thanks for the suggestion. It looks like this would work. I'm actually interfacing from python. I also found an pc_rpc.py to try out Jez's ideas. I'll let you guys know which one was easiest for me to implement. If I have any question I'll be sure to ask the you guys for suggestions. Thanks again.
dave
posted by Dave Tung 28 Feb 2013
11 years, 3 months ago.
thx
