11 years, 6 months ago.
DevStatus.imei won't return any string
Hey guys!
I'm currently developing a simple application using the MDM library and I need to store the SIM card IMEI on a string. Here's my code:
code snippet
mdm.dumpDevStatus(&devStatus);
printf("Imei:: %s \r\n",devStatus.imei);
As a result, the devStatus dump works normally, dumping every info available, but, when I print the same variable (IMEI) to test, it returns nothing.
Modem::devStatus Device: SARA-G350 Power Save: Disabled SIM: Ready CCID: 89552337111001356537 IMEI: 353816052697481 IMSI: 724233700600703 Manufacturer: u-blox Model: SARA-G350 Version: 08.49 Imei::
What could be causing this issue?
Thanks in advance,
