11 years, 7 months ago.
Issue with Wiz550io and Http echo back server
Hi all,
I am currently doing some tests with Wiz550io and a LPC1768.
More preceisely i try this program : https://mbed.org/teams/EthernetInterfaceW5500-makers/code/HTTPServer_echoback_WIZ550io/
Which is a version of the Http echo back server for the W5500.
Everything works well but only 7 times ! i can send 7 times a GET request (which succeed) and during the next request the MBED hang.
Do somebody have an idea to help to investigate ?
Best regards.
Patrick
There was a bug in socket::close() (socket.cpp) of EthernetInterfaceW5500 the code was
int Socket::close()
// add this code refer from EthernetInterface.
_sock_fd = -1;
return (eth->close(_sock_fd))? 0 : -1;
which is .... strange. i replaced it by :
int Socket::close()
int res;
res = eth->close(_sock_fd);
_sock_fd = -1;
return (res)? 0 : -1;
and now it works well
I also update http://mbed.org/teams/EthernetInterfaceW5500-makers/code/HTTPServer_echoback_WIZ550io/ project. Thanks.
posted by 23 Sep 2014Assigned to 11 years, 7 months ago.
