11 years, 8 months ago.
How do I change polarity of the SPI data pin on the FRDM K64F
I'm using the SPI interface on PTD1-PTD3 and the I/O pin polarity is inverted, e.g. logic high between output words. How do I change the default polarity to be logic low?
Thanks!
Michael
I believe that is the default on the Freescale ones, high output when not used. The clock polarity/phase can be changed to comply with the required SPI waveforms, but I don't think the SPI data polarity is ever defined. I believe for example the NXP microcontrollers put the data pin in high-Z mode when they aren't used.
If it is important for you, you can manually switch it to a GPIO input node, or low GPIO output. (I have had for example a situation where the SPI device could be disabled by turning of the power supply, but due to the high data pin on Freescale devices it was still semi-powered via ESD diodes).
11 years, 2 months ago.
FRDM_K64F, SPI MODE 3 Supposed to send 170 ( 0xAA), but received 171. It seems that the MOSI jumps up too early and makes the LSB always be "1". How can I solve the problem?
FRDM_K64F, SPI MODE 3 Test
SPI device(PTD6,NC,PTD5);
int i = 0;
device.format(8,3);
device.write(0x55);
device.write(0xAA);
wait(1);
I think it might be related to: https://github.com/mbedmicro/mbed/issues/840. It seems KSDK SPI peripheral (although iirc K20 uses the same one) has some timing issues with current code. Should get a seperate bug report on github.
posted by 11 Mar 201511 years, 8 months ago.
not sure, but in PIC (wow a long long time ago)
you set mode 0..3 or 1..4
