11 years, 8 months ago.
How to get a w5200 library works with the ST Nucleo L152RE ?
I try this https://mbed.org/components/Seeed-Ethernet-Shield-V20/ but it's not for the ST Nucleo L152RE.
Code snippet:
#if defined(TARGET_LPC1768) || defined(TARGET_LPC11U24) || defined(TARGET_LPC2368)
    static const PinName pin_names[] = {p5, p6, p7, p8, p9, p10, p11, p12, p13, p14
                                , p15, p16, p17, p18, p19, p20, p21, p22, p23
                                , p24, p25, p26, p27, p28, p29, p30};
#elif defined(TARGET_LPC1114)
    static const PinName pin_names[] = {dp1, dp2, dp4, dp5, dp6, dp9, dp10, dp11
                                , dp13, dp14, dp15, dp16, dp17, dp18, dp23
                                , dp24, dp25, dp26, dp27, dp28};
#elif defined(TARGET_LPC4088)
                                , p15, p16, p17, p18, p19, p20, NC, NC, p23
                                , p24, p25, p26, p27, p28, p29, p30, p31, p32
                                , p33, p34, NC, NC, p37, p38, p39};
#endif
#if defined(TARGET_LPC1768) || defined(TARGET_LPC11U24) || defined(TARGET_LPC2368) || defined(TARGET_LPC812) || defined(TARGET_LPC4088)|| defined(TARGET_LPC1114)
Edit: I think it was my mistake, had probably got an outdated Lib. This link works: http://mbed.org/teams/WIZnet/code/WIZnet_Library/
