11 years, 7 months ago.
Current bootloader source for Kinetis FRDM-K22F board
I'm looking for the current source code for the bootloader installed on the FRDM-K22F board. (Not the MBED loader) Either that or details about the file format expected by that bootloader.
The code available at : https://github.com/mbedmicro/CMSIS-DAP/tree/master/bootloader appears to be very out of date and is obviously different from the K22F loader. It still uses the older load address 0x5000.
I have existing files that work with the FRDM-K64F board that I relocated to the new load address of 0x8000 but they fail to load. There must be some other changes required.
Any pointers would be appreciated.
Thanks
Here is a snapshot of the source that is used to build that bootloader. https://github.com/mbedmicro/CMSIS-DAP/releases
The build comes from a branch that is being used to commonize the bootloader, flash algorithms and interface firmware projects. This will be merged to master in the coming months. https://github.com/mbedmicro/CMSIS-DAP/tree/refactor
