11 years, 8 months ago. This question has been closed. Reason: Duplicate question
NUCLEO-F401RE not sending anything on PC serial port
Hi all,
I just tried to use for the first time my NUCLEO-F401R4 board; I have two of these boards and I upgraded the ST-Link firmware to V2.J22.M5 as requested and I also upgraded the ST-Link driver on my PC (Windows 7 Pro, 64-bit).
I have developed the following simple program to measure the duration of the time period for wich the user presses the USER_BUTTON and to print it on the debug serial port:
Serial debug(SERIAL_TX, SERIAL_RX); // sends log messages via USB to PC terminal
InterruptIn button(USER_BUTTON);
DigitalOut led(LED1);
Timer tmr;
int count;
void button_pressed() {
tmr.reset();
tmr.start();
led = 1;
void button_released() {
tmr.stop();
led = 0;
count = tmr.read_us();
debug.printf("Pulse duration: %.3f ms\n", count/1000);
debug.baud(9600);
debug.printf("Hello, World!\n");
button.rise(&button_released);
button.fall(&button_pressed);
button.enable_irq();
while(1);
I can compile and upload my program whitout errors but nothing is sent on the serial port; I use Tera Term to receive data from the Nucleo board that is correctly enumerated (I can see the virtual COM port on my Device Manager).
I don't receive any character from my Nucleo board, even the initial "Hello, World!" is not displayed on the Tera Term window; I also tried with Putty but nothing happens.
However I can see that the program works correctly because when I press the USER_BUTTON, the LED is ON and it goes OFF only when I release the button.
The behaviour is the same for both boards.
Please can anyone help me to solve this problem?
I just solved the problem! It seems it was caused by some problem with the ST-LINK driver; I uninstalled and reinstalled it and now I get messages sent to the Virtual COM Port on my Tera Term window.
posted by Francesco Adamo 14 Aug 2014
