11 years, 8 months ago.
can anyone explain it??
I am working in websocketclient.cpp code in their i am getting struck in somewhre..whenever event_callback hapend it is making link to sockets.h (lwip)..In select_waiting() ...whyy it is happening to me..
event_callback(struct netconn *conn, enum netconn_evt evt, u16_t len) { int s; struct lwip_sock *sock; struct lwip_select_cb *scb; SYS_ARCH_DECL_PROTECT(lev);
LWIP_UNUSED_ARG(len);
/* Get socket */ if (conn) { s = conn->socket; if (s < 0) { /* Data comes in right away after an accept, even though
- the server task might not have created a new socket yet.
- Just count down (or up) if that's the case and we
- will use the data later. Note that only receive events
- can happen before the new socket is set up. */
SYS_ARCH_PROTECT(lev);
if (conn->socket < 0) {
if (evt == NETCONN_EVT_RCVPLUS) {
conn->socket
; } SYS_ARCH_UNPROTECT(lev); return; } s = conn->socket; SYS_ARCH_UNPROTECT(lev); }
sock = get_socket(s); if (!sock) { return; } } else { return; }
/* Set event as required */
switch (evt) {
case NETCONN_EVT_RCVPLUS:
sock->rcvevent++;
break;
case NETCONN_EVT_RCVMINUS:
sock->rcvevent;
break;
case NETCONN_EVT_SENDPLUS:
sock->sendevent = 1;
break;
case NETCONN_EVT_SENDMINUS:
sock->sendevent = 0;
break;
case NETCONN_EVT_ERROR:
sock->errevent = 1;
break;
default:
LWIP_ASSERT("unknown event", 0);
break;
if (sock->select_waiting == 0) { /* noone is waiting for this socket, no need to check select_cb_list */ SYS_ARCH_UNPROTECT(lev); return; }
