13 years, 1 month ago.
How do I use a wifly module in adhoc
I have a wifly module (http://uk.farnell.com/microchip/rn134-i-rm/module-wifly-gsx-802-11-w-rn-131/dp/2143319) and I can’t get the setup libraries to work, however I can just ad a jumper on the board that will set the board up in ad-hoc mode then I can see the network on my laptop and connect to it and ping the wifly module just fine.
So my question is, can I just use this configuration set up and use a tcp interface to simply send streams of data over using the wifly module (all I need is to send strings of data across) and if so does anyone have any idea how.
Edwin, Seed Software
