13 years, 1 month ago.
How to connect multiple serial devices to the same serial ?
I am currently running out of serial ports to connect several devices to mbed serial ports. I will have to use a serial multiplexer to connect 4 devices to the same port , say (p28, p27.
When in my program I write something like this:
Camera_LS_Y201 cam1(p28, p27); SMARTWAV sWav(p28,p27,p29); (TX,RX,Reset);
My serial port stops responding?
Does anybody know how to fix this issue and what are the solutions to connect 7 serial devices to 1 mbed ? You answer will be very appreciated. Thank you.
I have found that Camera_LS_Y201 refuses to work with its current library when the same serial pins have been assigned to other devices.
posted by Dim O 06 Mar 2013
