11 years, 8 months ago.
Where is the pin connection list please?
I realise it's using the SPI pins 5,6,7, that's fine.
- and I see three more connections for pins 24, 25, 26, but what goes where on these?
Apologies if I've missed it in the code, or elsewhere.
You should check out my Program http://mbed.org/users/Elitism/code/ILI9340C_Serial_Control/
posted by . . 28 Aug 2014
It lacks doxygen comments, but still the source file of the display lib: https://mbed.org/users/dextorslabs/code/ILI9340_Driver_Lib/docs/216d35e347b8/ILI9340__Driver_8h_source.html. So chip select, reset, and data/command pin.
+1 for bringing up doxygen comments !
posted by Martin Kojtal 21 Jul 2014
Hi Dan,
I really should make this more user friendly! - when time permits!
The program you referenced uses the library 'ILI9340_Driver_Lib', If you take a look at the code contained in the library files there are some clues, http://mbed.org/users/dextorslabs/code/ILI9340_Driver_Lib/#216d35e347b8
To compound Erik's answer - pin 24 is the chip select signal, pin 25 is the reset signal, and pin 26 is the data/command signal.
I hope this helps! Cheers, Ian.
Thanks to you both. I feel slightly awful because I figured it out just after posting the question - despite lots of looking prior to that! I think they call it sods law...
Thanks again! (I just wish it was so easy to get stuff up and running on a beaglebone. Been struggling to get this display working on that for about a week. I am going to look at porting your code accross)
So nice to have such great support for noobs!
Cheers, Dan
posted by Dan Steenson 21 Jul 2014
