13 years, 1 month ago.
MODSERIAL missing serial_api.h
Dear all,
I am trying to use MODSSERIAL (https://mbed.org/cookbook/MODSERIAL) in my program. This program used to compile, but when I import the MODSERIAL library and make the required adjustments I get the following error and therefore it won't compile properly:
Compiler Output Error:
Quote:
cannot open source input file "serial_api.h": No such file or directory
I also tried it with the very simple example provided:
#include "MODSERIAL.h"
MODSERIAL pc(USBTX, USBRX); // tx, rx
      pc.printf("Hello World!");
          pc.putc(pc.getc() + 1);
but this gives me exactly the same result.
The error explanation states that this could mean that the default mbed library is accidentaly removed. But this isn't the case.
Furthermore I have looked for an additional library called 'serial_api' that I might needed to import but I couldn't find anything.
What did I miss to import and use the MODSERIAL library properly?
Much thanks in advance
