11 years, 9 months ago.
Is there is way to Check out the voltage that supplied on the mbed board or Application board?
Hi I want to supply My mbed lpc 1768 by portable charger and I plug the micro usb either from mbed Application board or from mbed direct.. I want to write a code that help me to inform me by audiable that the battery level is law and theryby I am trying to find out a way to alert me that battery level is low.. Any help
You can use an Analog input to check the voltage. The function can be called at regular intervals using timer. You may have to use a resistor voltage divider to make that the analog input voltage stays within the allowed range of 0..3V3.
