11 years, 8 months ago.
NUCLEO-F401RE SPI issue
Hi All,
I am using SPI2 on NUCLEO-F401RE with following code.
pSPI=new SPI(PB_15, PB_14, PB_13);
pSPI->format(8,1);
pSPI->frequency(8000000);
While I am getting right data every couple of seconds getting incorrect data from salve. I am not sure but SPI clk doesn't look stable, is there any issue with SPI2 or SPI on this board?
Thanks, Ali
11 years, 3 months ago.
I am having the same problem. I have been using SPI for the master and SPISlave for the slave from the libraries and sometimes I get the correct behaviour but only for a while and then bogus. Did you find a solution?
I am not sure 100% but my problem was a noise caused by serial port. I switch to a different board from TI because I was looking MCU with WiFi
posted by 08 Dec 2014I am getting closer to the solution of my problem. Turns out even though both of the MCU's that I was testing were connected in the same laptop they still needed to have common ground so I connected the GND of each board and now I have much more stable behaviour even though I still have some synchronization issues.
posted by 11 Dec 2014
Do you have same issues with SPI0 or 1 (not certain now how many SPI modules it has) ???
SPI is tested on this board, should be functional.
posted by Martin Kojtal 11 Jul 2014Yes, same result. I am checking my slave now.
Thanks
posted by Ali Kian 11 Jul 2014
