11 years, 5 months ago.
PwmOut implemented on the K64F ?
Is PwmOut implemented on the K64F ??
See
/media/uploads/GerritPathuis/main.cpp
Used a wire to connect PwmOut(PTA0) and PwmIn(PTD1) and the mbed PwmIn Library to read the pulsewidth Cannot get it to work.
Thanks, Gerrit
Does it compile? Give an error message when you run it? How isn't it working?
posted by Erik - 05 Jul 2014
Yes it compiles and runs. It gives via Tera Term: period= 0.000000, pulsewidth= 0.000000, duty cycle= nan. My thoughts are that PwmOut is not working.
Thanks
posted by Gerrit Pathuis 05 Jul 2014
Sure you got the correct pins? And you can simply make some pulses by connecting the wire to ground/VDD to verify PwmIn is working.
Confirmed, PwmOut works of the K64F Thank you,
Gerrit
posted by Gerrit Pathuis 06 Jul 2014
11 years, 4 months ago.
Hi there,
See PwmOut_K64F_Basic, this is a very basic PwmOut program
and
/media/uploads/GerritPathuis/pwmout.jpg
The selected PwmOut pin is giving a 100 Hz, 50% duty cycle signal.
Thanks,
Gerrit
Assigned to Gerrit Pathuis 11 years, 5 months ago.
