11 years, 9 months ago.
lwip init network interfaces
Good day!
I want to make a client and connect it to netcat simple server.
1) Compilled lib with default settings and #define's (the only thing - i set some debug information on) 2) Linked lib to the project (works fine) 3) Set up virtual machine with ubuntu and made netcat working with
~$ sudo netcat -l -v 7
that means we are listening to port 7 (seven).
now I use ifconfig and get
inet addr:172.17.9.71 Bcast:172.17.11.255 Mask:255.255.252.0
fine for now.
4) ping and telnet work fine - I see that netcat is reachable by them .
my ifconfig stats are
inet addr:172.17.9.165 Bcast:172.17.11.255 Mask:255.255.252.0
5) Now I'm trying to connect to netcat server with my client, written by using lwip
output is :
LWIP_HAVE_LOOPIF = 0 LWIP_HAVE_LOOPIF = 0 tcp_bind: bind to port 55555 tcp_connect to port 7 netif_default = -780756800 netif_is_up(netif_default) = 0 ip_route: No route to 172.17.9.71 connect err = -4 netif_default = -780756800 netif_is_up(netif_default) = 0 ip_route: No route to 172.17.9.71 ip_output: No route to 172.17.9.71 Assertion "mem_free: mem->used" failed at line 339 in ../../../../../lwip/src/core/mem.c
the full listing :
const char *helloworld = "hello world\n";
void hello_end(struct tcp_pcb *pcb, u8_t *state)
tcp_err(pcb, NULL);
tcp_recv(pcb, NULL);
tcp_sent(pcb, NULL);
tcp_poll(pcb, NULL, 0);
mem_free(state);
err_t hello_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
u8_t *state = (u8_t *)arg;
u16_t len;
if (p == NULL)
if (*state == 255) /* close send */
hello_end(pcb, state);
else /* close not yet send */
*state |= 2;
else
len = p->tot_len;
pbuf_free(p);
tcp_recved(pcb, len);
return ERR_OK;
void hello_err(void *arg, err_t err)
mem_free(arg);
err_t hello_poll_close(void *arg, struct tcp_pcb *pcb)
if (tcp_close(pcb) == ERR_OK)
if ((*state & 2) == 2) /* close received */
else /* close not yet received */
*state = 255;
return ERR_OK;
err_t hello_connected(void *arg, struct tcp_pcb *pcb, err_t err)
tcp_write(pcb, helloworld, 12, 0);
return ERR_OK;
err_t hello_connect() {
lwip_init();
u8_t *state;
err_t err;
struct tcp_pcb *pcb;
ip_addr_t ipaddr;
IP4_ADDR(&ipaddr, 172,17,9,71);
if ((state = mem_malloc(1)) == NULL) {
return ERR_MEM;
*state = 1;
if ((pcb = tcp_new()) == NULL) {
mem_free(state);
return ERR_MEM;
tcp_arg(pcb, state);
tcp_err(pcb, hello_err);
tcp_recv(pcb, hello_recv);
tcp_poll(pcb, hello_poll_close, 10);
tcp_bind(pcb,IPADDR_ANY, 55555); //Bind ourselvs to the port 55555 and my own adress
err = tcp_connect(pcb, &ipaddr, 7, hello_connected);
if (err != ERR_OK) {
std::cout << "connect err = " << (int)err << std::endl;
mem_free(state);
tcp_abort(pcb);
getchar();
return ERR_OK;
int main(int argc, char** argv) {
err_t err = hello_connect();
std::cout << "2err = " << err << std::endl;
std::cout << "End of Main" << std::endl;
return 0;
return 0;
from here I started to think that the problem is that I didnt set up NETIF.
but I don't know HOW.
I think I don't want lwip to create tap0 by default
(it makes
tap0 Link encap:Ethernet HWaddr 86:97:2c:64:b7:78
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::8497:2cff:fe64:b778/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:33 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:0 (0.0 B) TX bytes:6555 (6.4 KiB)
I want to bind my application to localhost or to eth1 - whatever... How can I do this? What do I do wrong in my application?
By the way - when I do
char *eth = "eht1"; netif_set_default(netif_find(eth));
In my Init function I get this output
LWIP_HAVE_LOOPIF = 0 LWIP_HAVE_LOOPIF = 0 tcpip_thread: PACKET 0x7f72acaa1988 ip_input: packet not for us. tcp_bind: bind to port 55555 tcp_connect to port 7 netif_default = 0
and it falls on
(not passing it...)
Can some 1 help?
