11 years, 8 months ago.  This question has been closed. Reason: Off Topic
mbed-rtos and mbed-App-USBFlash Problem...
Hello there, Am trying to make a code by adding both "rtos" and "USBFlash" libraries but I get the following problem
Error: Invalid redeclaration of type name "BOOL" (declared at <a href="#" onmousedown="mbed_doc_goto('/mbed-USB_Data/FatFileSystem/integer.h', '27'); return false;">FatFileSystem/integer.h:27</a>) in "mbed-rtos/rtx/os_tcb.h", Line: 14, Col: 28
I even tried using the example code giving with the "mbed-App-USBFlash", but when I add "rtos.h" library, I still get the above error
Anyone knows how to fix it, please ?
Solved the problem , had to import the updated USBHost and edit the code again ..
posted by Mohammed Almoosawi 02 Jul 2014
