11 years, 9 months ago.
Seeeduino_Arch_Pro needs HW reset for debugging on LPCXpresso IDE
Hi
Am using LPCXpresso IDE for debugging on Seeeduino_Arch_Pro. But this seems very difficult when connecting debugger using mbedWinSerial_16466.exe(CMSIS_DAP).
At the time of debugging, LPCXpresso is throwing below error with an POPUP window.
10: Could not start execution from stop ACK Fault
Which is basically freezing my whole IDE. After doing modification(Vector catch :True & Attach only:True) in 'Launch Configuration->Edit Current->debugger' and disconnecting & connecting the USB cable again. Above error is not coming but the Board needs Pwr-ON reset to enter into and hit the main function.
Anyone please give some solution to this.
Regards!
