11 years, 9 months ago.
Problem with USBSerial class
I need to communicate a PC with other device, this device has an UART port and the communication occurs in raw mode at 115200 bps - 8N1. I'm using a mbed (LPC1768) board acting as a bridge between the PC and the device. When I connect the USB connector of the mbed board and implement below code, it works perfectly:
Serial RS500(p13, p14); // tx, rx
RS500.baud(115200);
if (pc.readable()) RS500.putc(pc.getc());
if (RS500.readable()) pc.putc(RS500.getc());
The problem occurs when I use the USBSerial class, I have implemented the hardware for the D+ & D- signals and the code below, but with this class the communication stops after few moments. Anyone has a suggestion?
#include "USBSerial.h"
USBSerial pc;
RS500.baud(115200);
Someone has a suggestion? I'm working with the latest versions of the libraries. Thanks and Regards
posted by Samuel Ramirez 02 Jul 2014
