11 years, 9 months ago.
E-Badge-Python-Utilities
Hi, Mr Liu.
I seek out your project to get display a image on my E-ink Display Shield. Especially, your image hex data shown bellow URL was the only success for my shield to display entire image data on it!. http://mbed.org/users/allankliu/code/LPC1114_EBadge/file/5032c106eea1/SSD1606/rom_image.h
But there are no converter, image data or documents on format( also SSD1606 's maker, E-Ink, and seeedstudio, etc). If you teach or notice me that how to make a graphics data from ordinaly BMP or JPG to 3096 2bytes array.
This image is evidence...
(sorry for incombinient to see Mirror image)
Sincerly Katsumi Imaizumi
Hi, Mr. Kat Ima,
Welcome to our mysterious world of EPD. Although your image is slow to load, I can identify that image, which is used as ESL demo project in China.
The EPD manufacturer is OED, Guangzhou, China. To be frank, I am not sure about its controller manufacurer, the original code indicates as "SPD2701". However I can not find it. I used "SSD1606" since I found it is quite similiar to solomon's description regarding SSD1606, and its hardware is similiar to SSD1306.
All of the manufacturers will ask you to sign "NDA" first to get the specification. And I got different specifications from them because I signed different versions of NDA. None of them are complete.
Yes, you have to contact OED to get full specification.
Basically I reused the demo code and ported it to ARM, now to mbed C++ API. So far so good. It works on mbed platform.
I have to admit, NDA is a roadblock. That's why I decide to develop an open source projects to allow the makers concentrate on high level applications.
Display Buffer
- OED 2.1" EPD is 172*72, with 2bpp, i.e. one byte for 4 pixels. (consider width=172)
- Its scans directions are: scanning from pixel (0,0) to (0,72), then from (1,0 to 1,72). That's so-called MODE 3. You can find MODE 1/2/4 with different scanning directions.
- By different regiser setup, you can get vertical and horizontal mirrored image.
- Most of the fonts scanning direction is horizontal, so you have to rotate everything or use vertical scan directions.
A very simple method can help you to figure out how it works. By using different bit patterns, for example, B/W in half, Grey in quad, Checkbox, line and strip. You can get from my code.
Another way is rotating the raw image. like this one.
Then it can show on screen as this.
So far I am working on mbed API, you have depend on yourself to make it work on Arduino.
I can show you my previous working Python code, the new version is still under development.
The Python code will print byte array on screen, just copy and past them into C/C++ code.
pil_demo_qrcode_basic.py
import Image
import ImageEnhance
import ImageOps
# More detail on PIL, please visit
# http://effbot.org/imagingbook/image.htm {{/media/uploads/allankliu/merged-172x72-rotate.png}}
# Allan K Liu
class panel:
def __init__(self,width=172,height=72,color="L",bpp=2,scan="v",endian="msb"):
width = width
height = self.height
color = self.color
bpp = self.bpp
scan = self.scan
endian = self.endian
def getRatio(self):
ratio = float(self.width)/float(self.height)
return ratio
def loadPanelParas():
pass
def readRawImage():
pass
def rotate(img):
pass
def resize(img):
pass
def move(img):
pass
def crop(img):
pass
def enhance(img):
pass
def merge(img):
pass
def codeGen(img):
pass
def printscreen(img):
iml = list(img.getdata())
for i in range(len(iml)):
val = iml[i]
print "%02X"%val,
print
def printscreen(img,x,y):
for i in range(y):
for j in range(x):
print "%02X"%(ol[j+i*x]),
print
main loop:
read panel params,
read raw image for dimension, histogram(dynamic range),
enhance(contract), rotate, resize, crop, merge
save it as *.bin file, with codegen in different coding style (c.*.asm)
def main():
bin = []
im = Image.open("merged-172x72-rotate.png")
panel = panel.Panel(172,72,"L",2,"v","msb")
#print im.format, im.size, im.mode
# Save it as a temp BMP file
# and invoke system default image viewer to show it
#im.show()
(x,y) = im.size
ratio2 = float(x)/float(y)
ratio3 = float(y)/float(x)
#print ratio2
#print ratio3
dither =im.convert(mode='P', dither=Image.FLOYDSTEINBERG)
#dither.show()
di = dither.convert('L')
bw = ImageOps.mirror(di)
#bw.show()
(b,p) = bw.getextrema()
print "B&W image ranges : %02X - %02X"%(b,p)
bw.point(lambda i: (0xFF-i)&0xC0).show()
#enh = ImageEnhance.Contrast(bpp2)
#enh.enhance(2).show()
(x,y)=bw.size
ol = list(bw.getdata())
#print "x=%d,y=%d,len=%d"%(x,y,len(ol))
print ">> co-ordinate"
for i in range(y):
for j in range(x):
print "%02X%02x"%(i,j),
print ""
print ">> value"
for i in range(y):
for k in range(x):
print "%02X"%(ol[k+i*72]),
print ""
print ">> array"
for i in range(len(ol)):
#print "%02X"%(ol[i]>>5),
print "%02X"%(ol[i]),
for i in range(len(ol)/4):
val0= ol[i*4]&0xC0
val1= (ol[i*4+1]&0xC0)>>2
val2= (ol[i*4+2]&0xC0)>>4
val3= (ol[i*4+3]&0xC0)>>6
val = val0+val1+val2+val3
#print "%02X=%02X:%02X:%02X:%02X(%02X:%02X:%02X:%02X)"%(val,val0,val1,val2,val3,ol[i],ol[i+1],ol[i+2],ol[i+3])
bin.append(val)
#print "len=%d"%(len(bin))
for i in range(len(bin)):
print "%02X"%(bin[i]),
#for i in range(len(bin)):
for i in range(172):
for j in range(18):
#print "0x%02X:(%02X,%02X,%02X),"%(bin[j+i*18],i,j,j+i*18),
print "0x%02X,"%(bin[j+i*18]),
print
if __name__=='__main__' :main()
Hi, Mr Liu. Thank you very much for your answer and your suggestion on NDA. I got it. If I use your code above, I process maker's NDA by myself. You told above means just this? (If it is wrong, please notice) I had an experiment by myself with ImageMagick and osx hexdump command. That was succeeded, but Avrdude explained "verification error; content mismatch". I guess that 0xff too much continued. But I had luck, could wrote down code into arduino again. verification mismatch occurs if I use displayable image hex code, so white pixels continuation are halmful I think. If you have any comment about this issue, please open it. If I make it solve, post that how to solve it later :-).
posted by 24 Jun 2014Hi, Kat Ima,
Yes, you have to contact OED to get full specification first. Or simply reusing source code from Seeedstudio and mbed.
I don't have a Mac, so I have no idea about hexdump.
Because EPD is only 2bpp for 4 grey level, so b00, b01, b10, b11 is valid for a pixel. 0xFF stands for full white for 4 pixels.
If you think continous 0xFF is harmful for checksum verfication, which may not be its root cause I guess. Athouth it has been reported by someone.
In order to test/verify that, you can use 0x00, 0x55, 0xAA, 0xFF for 3096 Bytes to have a smoke testing. Those stand for full black, grey 1, grey 2 and full white for whole screen.
Otherwise, you can randomly change 0xFF into any other values like 0xEE... every 128/256Byte. Single spark of pixel can be ignored from image.
Maybe you can try different Arduino IDE, even switch to Linux/Windows as cross-checking.
Yes. keep trying different ways to challange it.
posted by 24 Jun 2014Hi, Mr. Liu. I have a success to all of the image. I did 2 chars into one short. Simply 0xff >> 8 | 0x00ff. So, avrdude wrote that of all, and I wrote ino sketch to write two chars from short int. On Int, 0xffff => -9999, endof record => -10000, Int array was defined as short int. Thank you for your suggestion and teach indeed.
posted by 25 Jun 2014
