11 years, 4 months ago.
interfacing aubtm 20 bluetooth module with mbed..
i have a aubtm 20 bluetooth module and am integrating it with mbed . the bluetooth module is working fine as i had it tested by communicating between my laptop and a pc. i had coded mbed for simple transmitting of a letter.. which is supposed to print in the hyperterminal of pc.. can anyone shed light on this problem..?
I have no idea what you mean with this question. The AUBTM module apparently uses AT commands, so hooking it up over UART to your mbed board and then using ATCmdParser (part of Mbed OS) should allow you to communicate to the module.
posted by Jan Jongboom 05 Oct 2017
