11 years, 10 months ago.
how to use the Ticker ?
I would like to make a feature all the 90μs. For this I used
flipper.attach_us(&flip,90);
But I get in 60μs time interval, why ?
void flip() { //Envoi les valeurs automatiquement
if (fscanf(fp, "%d %d %d %d ", &dac, &val, &signe, &gain)!=EOF) {
if (dac==1) {
cs1 = 0; // Select the device by seting chip select low
else if (dac==2) {
cs2 = 0;
else if (dac==3) {
cs3 = 0;
else { /*if (dac==4)*/
cs4 = 0;
//lcd.printf("Val=%d \n\n",val);
spi.write(val); // Send 0x8f, the command to read the WHOAMI register
cs1 = 1; // Deselect the device
cs2 = 1;
cs3 = 1;
cs4 = 1;
else {
fseek(fp, 0, SEEK_SET);
Are you certain flip() does its job within 90us?
posted by Martin Kojtal 16 Jun 2014When I put 90μs I read the oscilloscope an interval of 60μs. When I put 150μs that's okay, I get good a time interval of 150μs. But as soon as I put the smaller values, it no longer works! Why?
posted by LouiseC LouiseC 16 Jun 2014how are you measuring the interval? I dont know your target, check the clocks for timer. I would calculate if it is possible to generate 90uS, using your clocking configuration (default mbed?).
posted by Martin Kojtal 17 Jun 2014I configured my connection SPI like this:
spi.format(16,1); Setup the spi for 8 bit data, high steady state clock, spi.frequency(1000000); second edge capture, with a 1MHz clock rate
The frequency is probably insufficient? I measure the time interval with an oscilloscope
posted by LouiseC LouiseC 17 Jun 2014
