11 years, 9 months ago.
To Wei Zou
Hi Sir,
My name is Dorothy.
I have tried out the main.cpp that you wrote and I could successfully compile. Thank God.
But I have one problem:
My problem is I could not get the whole string of HTTP output page. Instead of that the output was repeated:
I edited your main.cpp and it is shown below:
- include "mbed.h"
- include "GPRSInterface.h"
- include "HTTPClient.h"
- define TEST_HTTP_GET 1
- define PIN_TX P0_0
- define PIN_RX P0_1
GPRSInterface gprs(PIN_TX,PIN_RX,9600,"shppd",NULL,NULL);
HTTPClient http;
char str[512];
gprs.init();
while(false == gprs.connect()) {
printf("gprs connect error\n");
wait(2);
successful DHCP
printf("IP Address is %s\n", gprs.getIPAddress());
int ret;
HTTPText inText(str, 512);
HTTPText outText(str);
- if TEST_HTTP_GET
GET data
printf("\nTrying to fetch page...\n");
ret = http.get("http://www.mytransport.sg/busarrival/12101.json?_=1402902181703", str, 512);
if (!ret) {
printf("Page fetched successfully - read %d characters\n", strlen(str));
printf("Result: %s\n", str);
} else {
printf("Error - ret = %d - HTTP return code = %d\n", ret, http.getHTTPResponseCode());
- endif
gprs.disconnect();
return 0;
I was trying to get this output:
{"time":"16062014 150206","count":7,"bstop":"12101","info":
[{"wc2":"1","wc1":"1","bl2":"","bl1":"","arr2":"17","arr1":"5","bsvc":"52"},
{"wc2":"1","wc1":"1","bl2":"2","bl1":"1","arr2":"7","arr1":"3","bsvc":"61"},
{"wc2":"0","wc1":"0","bl2":"","bl1":"","arr2":"20","arr1":"9","bsvc":"74"},
{"wc2":"0","wc1":"0","bl2":"1","bl1":"1","arr2":"28","arr1":"11","bsvc":"75"},
{"wc2":"1","wc1":"1","bl2":"","bl1":"","arr2":"18","arr1":"5","bsvc":"151"},
{"wc2":"1","wc1":"0","bl2":"","bl1":"","arr2":"13","arr1":"6","bsvc":"154"},
{"wc2":"0","wc1":"0","bl2":"1","bl1":"1","arr2":"18","arr1":"9","bsvc":"184"}]}
But I could not produce the whole output but the output was repeated:
I got like this:
It was repeated:
May I kindly ask you that what would be the problems?
Thank you so much.
I am looking forward to hearing from you:D
Regards
Dorothy
I would like to encourage you to use proper headline, don't use "To username". Use more generic headline about the actual problem. It can be answered by other users who are familiar with the topic.
Use "
<<code>> <</code>>" for code highlighting !Thanks for understanding.
posted by Martin Kojtal 16 Jun 20140xc0170
Oh sir,
Thanks for your good advices.
posted by Dorothy Luai 16 Jun 2014
