11 years, 9 months ago.
Mysql client help
I am trying to set up a SQL client, https://mbed.org/cookbook/MySQL-Client. What I have so far is the following, however I get "Error 9 during connection" and "Error 3 during SQL Command", ANyone knows how to solve this? My database is called database, table -> ecgvalues, column -> values
#include "EthernetNetIf.h"
#include "MySQLClient.h"
#define SQL_SERVER "127.0.0.1"
#define SQL_USER "root"
#define SQL_PASSWORD "ecg"
#define SQL_DB "database"
EthernetNetIf eth(
IpAddr(192,168,2,12), //IP Address
IpAddr(255,255,255,0), //Network Mask
IpAddr(192,168,2,1), //Gateway
IpAddr(192,168,2,1) //DNS
MySQLClient sql;
AnalogIn Ain(p20);
float data_in;
MySQLResult sqlLastResult;
void onMySQLResult(MySQLResult r)
sqlLastResult = r;
printf("Start\n");
printf("Setting up...\n");
EthernetErr ethErr = eth.setup();
if(ethErr)
printf("Error %d in setup.\n", ethErr);
return -1;
printf("Setup OK\n");
Host host(IpAddr(), 3306, SQL_SERVER);
//Connect
sqlLastResult = sql.open(host, SQL_USER, SQL_PASSWORD, SQL_DB, onMySQLResult);
while(sqlLastResult == MYSQL_PROCESSING)
Net::poll();
if(sqlLastResult != MYSQL_OK)
printf("Error %d during connection\n", sqlLastResult);
//SQL Command
//Make command
char cmd[128] = {0};
data_in = Ain;
sprintf(cmd, "INSERT INTO ecgvalues (values) VALUES('%f')", data_in);
//INSERT INTO DB
string cmdStr = string(cmd);
sqlLastResult = sql.sql(cmdStr);
Net::poll();
printf("Error %d during SQL Command\n", sqlLastResult);
sql.exit();
while(1)
return 0;
9 years, 7 months ago.
Hi
Have you come far?
Your first problem is that your sql server does not have the IP address 127.0.0.1, but it is on a different IP address: 192.168.2.xxx
I'm not super into English so use google translate, sorry
hi
I have this same problem Error 9 during connection" and "Error 3 during SQL Command Solve the problem? Please help
posted by Balázs Kocsi 12 Mar 2015Sorry never solved the problem
posted by Johann Hur 12 Mar 2015
