11 years, 10 months ago.
how to use the Ticker ?
Hello, I would like to run a function every 100 microseconds. I used: flipper.attach_us(&flip,100); or flipper.attach(&flip,0.0001);
but in the two cases I get 62 microseconds apart. Why? thank you very much
Here's my flip ():
void flip() { //Envoi les valeurs automatiquement
if (fscanf(fp, "%d %d %d %d ", &dac, &val, &signe, &gain)!=EOF) {
if (dac==1) {
cs1 = 0; // Select the device by seting chip select low
else if (dac==2) {
cs2 = 0;
else if (dac==3) {
cs3 = 0;
else { /*if (dac==4)*/
cs4 = 0;
//lcd.printf("Val=%d \n\n",val);
spi.write(val); // Send 0x8f, the command to read the WHOAMI register
cs1 = 1; // Deselect the device
cs2 = 1;
cs3 = 1;
cs4 = 1;
else {
fseek(fp, 0, SEEK_SET);
Edit by 0xc0170: Please use code highlight syntax. Thx
