11 years, 9 months ago.
PWM on D9(PC_7)
Does this board have PWM out on D9(PC_7) pin? From the datasheet, it looks like it does and to have a true "Arduino form factor" it should have Pwm on D9(Otherwise its just stupid)
Affordable and flexible platform to ease prototyping using a STM32F302R8T6 microcontroller.
Ok, I've found this in the user manual: "Warning: PWM is not supported by D9 on STM32F302 since the timer is not available on PC7." Couldn't ST just route another pin? Congrats ST, you just made a board that supports Arduino connectivity withouth the connectivity.
posted by gelecek robotik 04 Jun 2014
Not certain about this case, but it's not always possible, there are also other platforms from other partners which have similar issues that some pins are used for other peripherals (which might have higher priority for use).
posted by Martin Kojtal 05 Jun 2014
