11 years, 9 months ago.
DigitalOut
I'm completely new to mbed. I have a good bit of programming experience, including using the Arduino IDE, but I'm having some issues with mbed on my F030R8 board using a simple DigitalOut code. When I try to blink D6 (PB_10) using the code below, it doesn't work when compiled for the F030R8 board. (And yes, the LED is attached properly, and I've already updated to the latest firmware on the board).
Code:
blink code
DigitalOut myled(D6);
myled = 1; // LED is ON
wait(2.5); // 200 ms
myled = 0; // LED is OFF
wait(2.5); // 1 sec
When I compile this same code for my F401RE board, it works just fine. Also, changing the pin to D7 seems to make it work on both boards. I have now tried it on 2 different F030R8 boards, and both behave the same way. I'm sure I'm doing something stupid, so I'd appreciate some help from the experts to get me going in the right direction.
Thanks.
Hello Agent Orange,
as I see it from sources,
LED1 = PA_5,
LED2 = PA_5,
LED3 = PA_5,
LED4 = PA_5,
Same is for 401 target. Replace D6 by LED1 and see if that works for both platforms.
0xc0170
LED is connected to PA_5.
