11 years, 9 months ago.
Updating KL25Z firmware
So I know this should be too hard, but I'm afraid I bricked my board. Can someone direct me to how to update the firmware on my KL25Z? I started it up with the reset button down and the BOOTLOADER drive showed up in Linux. I copied various files to the drive that I thought would update the firmware, but I'm not sure if I got the right one. I read somewhere I need to update first to one version because my firmware is less than 1.10. Than go to the SDA version. Anyway, I can still get the board to bring up the BOOTLOADER drive, but if I don't hold down reset the 'normal' drive doesn't show up anymore, and I can't get the 'mbed' drive to show up either. Thanks.
Board Name is: FRDM-KL25Z MicroBoot Kernel Version is: 1.05 Bootloader Version is: 1.09 Application Version is: 0.00
Sorry, figured it out. Just needed to do from windows.
posted by Josh Grauman 31 May 2014
OK, thanks for letting us know it's solved. Closing..
Assigned to Josh Grauman 11 years, 9 months ago.
