11 years, 9 months ago.
Signalling the "main" thread in RTOS
As I understand it, "main" is a defined thread when running the RTOS.
How do I reference the main thread, for example to set a signal in another thread?
I tried main.signal_set(0x1); for example but this does not compile, saying "main" is undefined.
Chuck
You can't call main.signal_set(0x1) because main is not a Thread object, it's just a function. What you need to do is figure out main's thread ID by calling Thread::gettid() within the main thread. This will give you an osThreadId variable that you can use with the regular CMSIS-RTOS functions. Calling osSignalSet(yourMainThreadID, 0x1) will do the trick.
