11 years, 9 months ago.
UDP Socket Issue
I am having a problem with the UDP Socket object. I am using an EA-LPC4088. Below is some example code where I am expecting the receiveFrom() method to timeout after 1000msec. However, it never times out if there is no packet traffic. Am I doing something wrong or is there an issue with the EthernetInterface class?
Tom Doyle
Include EthernetInterface and mbed-rtos libs with with example
include "EthernetInterface.h"
DigitalOut myled(LED1, 1);
EthernetInterface gEth;
UDPSocket gSocket;
    printf ("Starting Program\r\n");
    if (gEth.init("195.0.0.6", "255.255.255.0", "195.0.0.1") < 0)
        error("FATAL Error: Ethernet Initialization Error\r\n");
    if (gEth.connect(10000) < 0)
        error("FATAL Error: Ethernet Connection Error\r\n");
    if (gSocket.bind(4323))
        error("FATAL Error: Unable to bind ALXT_MSG_PORT socket");
    gSocket.set_broadcasting(true);
    //gSocket.set_blocking(true, 1000);
    Endpoint source;
    char receiveBuf[512];
    while(1)
        gSocket.receiveFrom(source, (char*)receiveBuf, sizeof(receiveBuf));
        myled = !myled.read();
