11 years, 10 months ago.
HTTPClient-Xively set up ?
Hi Interested in put request using Xively but how to set up and use this code?
Hi, Please import the code, then replace your ID and API into lines 7 and 8. The location PUT request is in json format at line 76. Replace it with your actual location. The code currently uses the default location in Xively API document: https://xively.com/dev/docs/api/metadata/waypoints/ Regards Chau
