11 years, 9 months ago.
lpc 1549 export to LPCexpresso
Hi, I am wondering if mbed is going to support code export for lpcexpresso compiler or not .Right now it is only possible to export for keil. Is this feature going to be available at some point ? Thanks
Assigned to 11 years, 9 months ago.
I know this is not an solution, but the Keil MDK has 32k code size for free. Unfortunately I started using Keil more because of the same issue on the LPC812.
posted by Travis Travelstead 23 May 2014My friend is working on this. :-)
posted by Yoshihiro TSUBOI 24 May 2014Dear Ahmari, I send to git-hub mbed repository today. I checked to mbed-sdk GCC_CR. if you need mbed-sdk export to LPCexpresso, please check to the this git on the https://github.com/Kazu-zamasu/mbed/tree/1549. If this code is confirm from mbed administrators, I think may be enable on the online mbed compiler export command. Regards, kazu.
posted by Kazu Zamasu 11 Jun 2014
