13 years, 2 months ago.
disable pin interrupt
Hi, I have an interrupt pin working but I need to disable it (interrupts become very frequent). Can this be done?
Thanks, Ian
To disable an interrupt you can use the same function as the one you used to enable it, but instead of giving it a pointer to your function, give it a NULL pointer. So for example:
interrupt_pin.rise(NULL);
