11 years, 10 months ago.
problem with LCD 16*4
hello, im doing my senior project and i have a problem with my LCD 16*4 (LCM1604b) my program is working on protues and it is working with LCD 16*2 but when im using 16*4 it is not, any advice? thank you
What exactly is 'not working'. Be more specific. Are you using the TextLCD lib? Did you select the 16x4 display type.
when i connected the LCD 16*2 (hardware) it functioned normally, but i changed it to 16*4 it displayed black squares, and i didn't know what it was i had to change, im using assembly language with PIC18F4450. so i don't know if i have to change something in the hardware or in the program. if its in the program and you have just the part for the LCD it will be perfect, and if its in the hardware connection what could it be. Thank you for you continues help.
posted by firas nassereddine 17 May 2014
First of all, this forum is intended only for the mbed platform ARM hardware and software. Please post your questions on a site for the PIC line. When the LCD shows black rectangles it means that powersupply is OK, but the display is not initialised properly. Check your wiring (data, Enable, RW, RS) and check the timing for the init sequence.
posted by Wim Huiskamp 18 May 2014
