11 years, 10 months ago.
Cannot find lwipopts_conf.h
I'm writing a HTTP client that uses the HTTP client library. I've imported the libraries: mbed-rtos, lwip, Socket and HTTPClient. However I cannot compile becuase of this error:
Error: Cannot open source input file "lwipopts_conf.h": No such file or directory in "lwip/lwipopts.h", Line: 22, Col: 27
Which library must I import to get my hands on lwiopts_conf.h.
I've looked without success.
Thanks,
Ravi/
what target are you using? That could be a problem. Did you check revision of each libraries you imported?
conf header file should be part of lwip library. I looked at github mbed repo. The header for K64F is located mbed\libraries\net\eth\lwip-eth\arch\TARGET_K64F\lwipopts_conf.h for instance.
0xc0170
