11 years, 10 months ago. This question has been closed. Reason: Unclear question
Ax12 hello world and motor ids. A small tiny help please.
So ive been trying out mbed with ax-12w. Ive been able to run the Ax 12 hello world. First of all ive set 2 motors id. Id 1 & id 2. So as you can see ive tried to declare the id "int CurrentID=1; int NewID=1;" in the program below and it seems that my motor with the id 1 is moving. But is this the correct way to declare an id in a program? My main objective is to control 2 motor in a single program. By declaring the id as stated in the program below, in which way can i declare the id 2 so that i can control 2 motors at a time. Can someone tell me how do i declare the proper way? Or if im right...How do i declare multiple motor id in a program. Your reply will be much appreciated. :D
#include "AX12.h"
int CurrentID=1;
int NewID=1;
AX12 myax12 (p9, p10, 1);
while (1)
myax12.SetGoal(0); // go to 0 degrees
wait (1.0);
myax12.SetGoal(300); // go to 300 degrees
wait (1.0);
myax12.SetGoal(150);
wait (1.0);
You probably get a warning that those two ints are ignored, at least I don't see why it would do anything with it. If you look at the functions there is one to change the ID of a servo. The used ID is simply the third argument of the constructor ('1' in this code).
posted by Erik - 16 May 2014
