11 years, 10 months ago.
cannot export program from compiler
I am having a problem exporting program to keil or any other compiler. When I select export I get the "waiting for mbed.org" and then "Downloading file" in the bottom left corner, but nothing happens.
thank for your help
B
Might help web guys, what browser are you using, what target?
posted by Martin Kojtal 08 May 2014
I tried using both chrome and Internet Explorer. I am using LPC1768 and tried both Keil and LPCxpresso with no luck.
posted by Barnaby Portelli 08 May 2014
I can say it depends on browser. Can you try on another computer?
Ok just realized that the problem occurs only when I convert the mbed settings into a library. I managed to download the project but I used to be able to export the project with the mbed library converted
I have experienced the same thing with the TCPSocket_HelloWorld example when I chose to convert the "mbed" library reference into the full library source.
This happened with both Chrome and Safari under Mac OS/X.
Perhaps there is a size or time limit that is being exceeded in this case?
posted by Ned Konz 06 Nov 2014
