11 years, 11 months ago.
Using multiple serial ports on NUCLEO_L152RE
I am trying to find out the pin definitions that can be use for multiple serial ports on the NUCLEO_L152RE. I got the first one is connected to ST-LINK so cannot be used directly without having to change solder jumpers on board. I got the second UART working fine using PA_9, PA_10 which I found on a previous question that was posted. However I need two ports that I can use directly. So I need the pins that can be used for the third Serial connection. I don't know if I simple need the pin names or is there some configuration that needs to be done to use the third Serial port. Thanks in advance for any help.
Here is the complete list of currently defined pin options:
static const PinMap PinMap_UART_TX[] = {
    {PA_2,  UART_2, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART2)},
    {PA_9,  UART_1, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART1)},
    {PB_6,  UART_1, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART1)},
    {PB_10, UART_3, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART3)},
//  {PC_10, UART_3, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART3)},
    {PC_10, UART_4, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_UART4)},
    {PC_12, UART_5, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_UART5)},
    {NC,    NC,     0}
static const PinMap PinMap_UART_RX[] = {
    {PA_3,  UART_2, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART2)},
    {PA_10, UART_1, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART1)},
    {PB_7,  UART_1, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART1)},
    {PB_11, UART_3, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART3)},
//  {PC_11, UART_3, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_USART3)},
    {PC_11, UART_4, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_UART4)},
    {PD_2,  UART_5, STM_PIN_DATA(GPIO_Mode_AF, GPIO_OType_PP, GPIO_PuPd_UP, GPIO_AF_UART5)},
    {NC,    NC,     0}
