11 years, 11 months ago.
will the sorce be published?
I am a hobby now play with this platform, I thought it is amazing. how about to use this platform to build real project, will the source code be published. is it secure to build a private project have source code security.
Sincerely.
David Sun
If you just keep the code on your account in the online compiler, nothing is published and no-one can see it. You can then decide to publish it, and you will get a question to publish it either as public: Everyone can see it, non-listed, everyone with the link can see it, but it won't show up on search results, or as private, in which case only those you explicitly give access can see it.
You can also use an offline compiler, and do it like you would do with other platforms. (https://mbed.org/handbook/Exporting-to-offline-toolchains)
