11 years, 11 months ago. This question has been closed. Reason: already posted
Can anybody expain this program??
hello, i need to know what exactly this code is doing?? i m not able to understand This is the program to get the RSSI from XBEE can anybody help?
XBEEGETRSSI.CPP
#include "XBeeGetRssi.h"
//#include <string.h>
XBeeGetRssi::XBeeGetRssi(PinName tx,PinName rx){
_tx=tx;
_rx=rx;
char* XBeeGetRssi::_getRssi(/*int n*/){
//int judge_counter=0;
int rssi_counter=2;
//int xbee_message_counter=0;
Serial pc(USBTX,USBRX); //for debugging.
Serial _MyXbee(_tx,_rx);
_rssi[0]='0';
_rssi[1]='0';
for(int i=2;i<20;i++){
_rssi[i]='0'; //initial value
_MyXbee.putc('T');
wait(1.0);
_MyXbee.putc('+');
wait_ms(1);
_MyXbee.putc('+');
wait_ms(1);
_MyXbee.putc('+');
wait_ms(1);
//judge_counter=0; //reset counter for later use
wait(1.0);
_MyXbee.putc('A');
wait_ms(5);
_MyXbee.putc('T');
wait_ms(10);
_MyXbee.putc('D');
wait_ms(10);
_MyXbee.putc('B');
wait_ms(10);
_MyXbee.putc('\r');
wait_ms(10);
while(_rssi[judge_counter++]!='\0'){
while(_MyXbee.readable()){
_rssi[rssi_counter++]=_MyXbee.getc();
if(_rssi[5]=='T'){
_rssi_address=&_rssi[9];
}else{
_rssi_address=&_rssi[0];
_MyXbee.putc('A');
wait_ms(5);
_MyXbee.putc('T');
wait_ms(5);
_MyXbee.putc('C');
wait_ms(5);
_MyXbee.putc('N');
wait_ms(5);
_MyXbee.putc('\r');
return _rssi_address;
int XBeeGetRssi::getRssi(/*int n*/){
int _rssi_value=0;
_returned_rssi=_getRssi();
switch(*_returned_rssi){
case '0':
_rssi_value+=0;
break;
case '1':
_rssi_value+=(int)(*_returned_rssi-0x30)*16;
break;
case '2':
break;
case '3':
break;
case '4':
break;
case '5':
break;
case '6':
break;
case '7':
break;
case '8':
break;
case '9':
break;
case 'A':
_rssi_value+=(int)(*_returned_rssi-0x31)*16;
break;
case 'B':
break;
case 'C':
break;
case 'D':
break;
case 'E':
break;
case 'F':
break;
default:
_rssi_value+=0;
break;
switch(*(_returned_rssi+1)){
case '0':
_rssi_value+=0;
break;
case '1':
_rssi_value+=(int)(*(_returned_rssi+1)-0x30);
break;
case '2':
break;
case '3':
break;
case '4':
break;
case '5':
break;
case '6':
break;
case '7':
break;
case '8':
break;
case '9':
break;
case 'A':
_rssi_value+=(int)(*(_returned_rssi+1)-0x31);
break;
case 'B':
break;
case 'C':
break;
case 'D':
break;
case 'E':
break;
case 'F':
break;
default:
_rssi_value+=0;
break;
return -1*_rssi_value;
XBEEGETRSSI.h
ifndef XBEEGETRSSI20130718
#define XBEEGETRSSI20130718
class XBeeGetRssi{
public:
XBeeGetRssi(PinName tx,PinName rx); //select the oneshot mode or repeat mode.
int getRssi(/*int n*/); //method for getting rssi.
private:
PinName _tx;
PinName _rx;
char _rssi[256]; //arrangement for containing the rssi value.
char* _rssi_address; //value before caluculate.
char* _getRssi();
char* _returned_rssi; //return value after calculate
//char _return_rssi_value[10];
//int _rssi_value;
#endif
