11 years, 12 months ago.
Embedded Artists GPS module
Does anyone know if the Embedded Artists GPS module is compatible with the MBED Application Board with the LPC1768 board installed? The board outline and connector positions look "remarkably" like the Zigbee and WiFi modules.
11 years, 11 months ago.
I haven't tested myself, but as far as I can see it should work. The GPS module is only using the RX and TX pins from the "XBee connector".
Andreas @ Embedded Artists
Thanks, It's worth a try. I can configure the Tx and RX pin allocations in the published application. Tack för din hjälp
posted by Julian Cox 11 Apr 2014
