13 years, 1 month ago.
Serial Parity Issue
I'm attempting to use a parity bit within my application with little success. To eliminate an issue with my code I've tried to incorporate a parity bit into a simple application (as shown below) and this doesnt appear to work either. I would expect, as there appears to be no error handling, that the receiver would just scrap the incomming packet. What I see is the receiver acknowledging any character transmitted using a standard hyperterminal configured with both odd and even parity.
Can anyone see what I'm doing wrong? Has anyone used the parity check within serial.h?
DigitalOut led1(LED1);
DigitalOut led2(LED2);
Serial pc(USBTX, USBRX);
void callback() {
// Note: you need to actually read from the serial to clear the RX interrupt
printf("%c\n", pc.getc());
led2 = !led2;
pc.format(8,Serial::Odd,1);
pc.attach(&callback);
while (1) {
led1 = !led1;
wait(0.5);
The documentation does not say explicitly but it would be unusual for the code to discard RX characters with bad parity - you sometimes want to see these. I guess you'll have to read the line status register yourself directly and check the PE bit (2). See also http://mbed.org/forum/mbed/topic/1201/
