12 years ago.
RPCFunction call from MATLAB R2014a
I'm trying to call an mbed function from MATLAB 2014a and not had much luck.
The output from MATLAB is:
Matlab output
 Successfully connected to mbed
Objects that can be created or used:
  RangeFinder AnalogOut Serial BusInOut BusIn BusOut Timer PwmOut DigitalInOut DigitalOut DigitalIn AnalogIn Base
Tied MATLAB to existing RPCFunction on mbed
Error using mbed.RPCFunction/run (line 42)
Not enough input arguments.
Error in mbedB (line 11)
range = RangeFinder.run;
Looks like there is an issue in passing arguments, but the mbed example online didn't try pass anything
The MATLAB M file is based on code from the Rangefinder example
Code on Matlab to call function on mbed
 mymbed= SerialRPC('COM5', 9600);
%device = Serial(mymbed,'%s');
%if you need to reset mbed
mymbed.reset;
%Attach to an Existing RPCFunction on mbed
RangeFinder = RPCFunction(mymbed, 'flip');
%Run its methods
mymbed.delete;
clear;
Here is the code I have on the mbed
RPCFunction test
#include "mbed-rpc.h"
SerialRPCInterface RPC(USBTX, USBRX);
void flip(char *input, char *output);
Timeout flipper;
DigitalOut led1(LED1);
DigitalOut led2(LED2);
void flip(char *input, char *output)  {
    led2 = !led2;
    led2 = 1;
    RPCFunction RangeFinder(&flip, "RangeFinder");
    // spin in a main loop. Matlab will interrupt it to call flip
        led1 = !led1;
        wait(0.2);
