12 years ago.
LPC11U35FBD64
Hi All, Are there any problems in programming the 64 pin version of the LPC11U35 using mbed?
Cheers
12 years ago.
You should be able to run the same code on that as the 32-pin LPC11U35, my only concern would be if the extra pins work or not. If I recall correctly they're all defined in the mbed library, so your best bet would be to try it. I've run code compiled for a 64-pin LPC11U24 on a 32-pin LPC11U35 without issue before.
